How can I display a custom dialog box in ArcGis Pro using Python?
1879
06-24-2022 09:44 AM
LuisEduardoPerezGraterol
Hello
In ArcGis Desktop I can create a dialog box using Python and Tkinter.
Can I do something similar in ArcGis Pro?
Apparently I can't use Tkinter in ArcGis Pro, I can't import it, but is there an equivalent alternative?
JohannesLindner
ArcGIS Pro uses Python 3.X (ArcMap uses 2.7.X I think). TKinter was renamed to tkinter.
You could try using that. In my experience, Pro and Python guis don't play very well together. Save your work before you try, there's a good chance Pro will crash or freeze.
I belive the way to do something like that would be writing your own AddIn.
But that seems like a lot of hassle for a simple dialog window.
For a simple message box, something like this could suffice:
import webbrowser
def open_dialog_box(message):
    path = "H:/dialog_box.txt"  # some location you have write access to
    with open(path, "w") as f:
        f.write(message)
    webbrowser.open(path)
open_dialog_box("Hey there!")
Have a great day!
Johannes
JohannesLindner
import webbrowser
        f.write(message)
Have a great day!
Johannes
Thanks, this works!!!
I have to study the addins
