I am trying to create a hillshade from a mosaic dataset I created from DEMs for portions of Massachusetts, Connecticut, and Rhode Island. My mosaic raster looks correct, but the hillshade tool creates a strange grid pattern not at all representing the elevation data in the mosaic. I am not sure what would cause this or how to resolve it. Thoughts?
Mosaic DEM above
Hillshade product from tool.
Interesting! So a question for you - what is the coordinate system of the raster mosaic? Is it a geographic or projected coordinate system? If geographic (i.e. WGS 1984 for example), I would recommend you run the Project Raster GP tool first to UTM or Stateplane. Then run the Raster Function again. Does the output change to expected results?
@kwatter48 did you ever resolve this? I am running into a similar problem (also in CT).
At a scale of around 1600, it looks normal:
But if I zoom in one more roll of the mouse wheel, it looks horrible (like I'm watching reruns on an old black & white TV using an antenna):
This is how bad it gets at 1:240:
Same area/scale from an older hillshade created using ArcMap and an older DEM:
To answer @Robert_LeClair question, as least for me, I am using CT Stateplane projection.
Interesting...with regards to your Mosaic Dataset, have you built overviews for the MDS? Also, can you share the data with me so I may test on my side to figure out what's going on? Thx!
maybe bump this setting way up > "Maximum Number of Rasters Per Mosaic"
or do that and then blow out the existing overview and recreate them
or do that and create a fresh file geodatabase, fresh mosaic dataset, etc.
The steps I was using to create a Hillshade layer, detailed below, were not the best approach.
A colleague at CT ECO, who had built out the Connecticut statewide hilldshade, recommended creating a Mosaic Raster dataset referencing the individual DEM tiffs. Then using the GP Tool Hillshade, I was able to create a nice clean Hillshade layer.
The result is much better at 1:240. Hope this can help somebody else. . . .
This was how the old/wrong approach looked:
Thanks for the replies just the same.
