Hillshade Tool Returns Strange Grid
2533
10-18-2024 03:45 PM
Labels (2)
kwatter48
I am trying to create a hillshade from a mosaic dataset I created from DEMs for portions of Massachusetts, Connecticut, and Rhode Island. My mosaic raster looks correct, but the hillshade tool creates a strange grid pattern not at all representing the elevation data in the mosaic. I am not sure what would cause this or how to resolve it. Thoughts?
Mosaic DEM above
Hillshade product from tool.
Tags (3)
Robert_LeClair
Esri Esteemed Contributor
Interesting!  So a question for you - what is the coordinate system of the raster mosaic?  Is it a geographic or projected coordinate system?  If geographic (i.e. WGS 1984 for example), I would recommend you run the Project Raster GP tool first to UTM or Stateplane.  Then run the Raster Function again.  Does the output change to expected results?
PLadd
@kwatter48 did you ever resolve this?  I am running into a similar problem (also in CT).
At a scale of around 1600, it looks normal:
But if I zoom in one more roll of the mouse wheel, it looks horrible (like I'm watching reruns on an old black & white TV using an antenna):
This is how bad it gets at 1:240:
Same area/scale from an older hillshade created using ArcMap and an older DEM:
To answer @Robert_LeClair question, as least for me, I am using CT Stateplane projection.
Robert_LeClair
Interesting...with regards to your Mosaic Dataset, have you built overviews for the MDS?  Also, can you share the data with me so I may test on my side to figure out what's going on?  Thx!
BillFox
MVP Notable Contributor
maybe bump this setting way up > "Maximum Number of Rasters Per Mosaic"
or do that and then blow out the existing overview and recreate them
or do that and create a fresh file geodatabase, fresh mosaic dataset, etc.
PLadd
The steps I was using to create a Hillshade layer, detailed below, were not the best approach.
  • From over 200 smaller DEMs, I had created a city-wide raster.tif DEM.
  • Then I used this city-wide DEM to build the Hillshade raster, first using the Hillshade function and then trying the GP Tool Hillshade
  • Both yielded the same fuzzy result.
A colleague at CT ECO, who had built out the Connecticut statewide hilldshade, recommended creating a Mosaic Raster dataset referencing the individual DEM tiffs.  Then using the GP Tool Hillshade, I was able to create a nice clean Hillshade layer.
The result is much better at 1:240.  Hope this can help somebody else. . . .
This was how the old/wrong approach looked:
Thanks for the replies just the same.
