Help with SDE Dataset Permissions
2436
03-02-2020 07:32 PM
aam
Any SDE Database experts here? I have a question regarding SDE objects.
So I have an enterprise Geodatabase set up with three user accounts. Admin/Sys (That's me), Viewers, and Editors. I have data organized using number of datasets within the Database. Recently I was asked to create a new Dataset within our Database. This new Dataset would contain specialized data featureclasses that every user would have access to.
I have created this Dataset and brought in the required feature classes. However, the challenge I am having is that the Dataset is only visible to me since I am using the Database Admin user account. It is not visible to all the other users.
Do anyone know why this might be, and what do I need to do to rectify this problem. Does this have anything to do with the permissions and privileges?
Asrujit_SenGupta
Yes, you need to grant the desired users Privileges to View (Select) the Feature Dataset, otherwise they won't be able to view it.
Grant and revoke dataset privileges—ArcGIS Help | Documentation
Change Privileges—Help | Documentation
Asrujit_SenGupta
aam
Thank you! This is exactly what I needed.
