Data Interoperability Issue: Data Interoperability for ArcGIS Pro requires an All Users installation for ArcGIS Pro 2.5.
4545
02-27-2020 08:31 PM
XavierMurray1
Geo-Friends,
Might be a rookie question but, I have a single use licence for ArcGIS Pro 2.5 with Data Interoperability licenced.
I have the downloaded exe for Pro 2.5 Data Interoperability.
When i try to run the install i get the following error message and the wizard fails:
Data Interoperability for ArcGIS Pro requires an All Users Installation for ArcGIS Pro 2.5
Any advice would be appreciated.
thank you.
xaviermurray
Thanks Dan,
Turns out that all i had to do was uninstall ArcGIS Pro and re-install.
when prompted during the new install, select all users of this pc radio button instead of just my account.
DanPatterson_Retired
I guess you didn't install an "all users" pro.  Smart if you are the only one using the machine, since you can install it where you want.  That leaves the hoop
Single use
Single-use installations of theArcGIS Data Interoperability extensionrequire an authorization file. If yourArcGIS ProSingle Use installation is not licensed to use theData Interoperabilityextension, you can obtain an authorization file at the Esri Customer Care website.
Installing the ArcGIS Data Interoperability extension—ArcGIS Pro | Documentation
So no biggie... you can get a license file
xaviermurray
Thanks Dan,
