Help: Map to KML tool is not showing display settings in Google Earth when set properly in ArcGIS Pro
1302
08-06-2024 08:11 AM
DustinFerguson
Hello,
Every time I export my KML/KMZ map the settings in Google Earths table of contents does not show the display setting I set within Pro. The fields are populated with my data and the coordinate systems match up throughout. Has anyone had this problem or know a solution? I have attached some screenshots below with my display, the data, and what I see in Google Earth. Thank you for the help!
SeaRM
Try to use XTools Pro Export to KML tool for that.
https://xtools.pro/en/features/importexport-tools/export-to-kml/
DustinFerguson
Thank you for the suggestion @SeaRM . Do you have a free option or one that doesnt require a subscription?
SeaRM
@DustinFerguson Yes, of course, I typed you the private message.
