Help calculating field with arcade using two other fields including date range
2204
02-17-2022 11:15 AM
AshleeWolf525
I am new to Arcade and using ArcGIS Pro to calculate a field using an arcade expression.
I would like to calculate a field called "Eligiblity" with the domain "Eligible", "Not eligible", and "NA" based on two other fields: Status and Date.
There is one value in the "Status" field that I want to be classified as "NA" and three other values that are "Eligible for recollection" IF the event occurred more than 3 years ago and "Not eligible for recollection" if the event was within the last three years.
Basically as follows in plain English:
- If Status is Scouting return NA
- If Status is anything other than scouting (including SWSP Collection, Recollection SWSP, SOS Collection) and Date is before 12/31/2018, return Eligible
- If Status is anything other than scouting and Date is after 12/31/2018, return Not eligible
Here is what I have tried:
if($feature.STATUS is "Scouting") {return "NA"}
else if($feature.DATE <=Date(12/31/2018)) {return "Eligible for recollection"}
else {return "Not eligible for recollection"}
HuubZwart
Very close, few pointers:
== is the syntax to check for equal to condition, not IS
Check syntax for date function, you need Date(2018, 12, 31)
Make sure the capitalization of attributes match (i.e. STATUS is not equal to Status)
Make sure your output matches your domains (Eligible for recollection vs Eligible)
HuubZwart
AshleeWolf525
Thank you! Those tips did the trick. The following is what I ended up with, if it's helpful to anybody in the future:
if($feature.Status=="Scouting") {return "NA"}
else if($feature.Date <=Date(2018,12,31)) {return "Eligible for recollection"}
