Having difficulty with sorting points spatially
2251
9
05-19-2020 12:19 AM
WilliamDochnahl
I am trying to sort a large number of points spatially to then create lines and polygons that follow the points. I am using a PEANO sort to attempt to sort the points, but they don't sort in an order that makes a lot of sense to me. Is there something I can do to get these to sort in an order that will allow me to generate lines or polygons around the outside of these features?
Bill Dochnahl
DavidPike
MVP Notable Contributor
How did you get the points initially? Instead of trying to unbake that cake maybe we can save it from the oven in the first place.
there could be some near analysis done on it, but that is a bit chicken and egg again as it would need to iterate sequentially.  I can see how it might be done in my head though.
WilliamDochnahl
They are part of a large point file that sent to me derived from LiDAR data. I don't have a way to change how the other group processes that data, so this is what I have to work with.
JoshuaBixby
MVP Esteemed Contributor
What do the points represent?
WilliamDochnahl
These are the outside edges of an unpaved road.
BruceHarold
Esri Frequent Contributor
The Aggregate Points tool can cluster groups of points but your data appears track-like, do you want Points To Line linear output?  There are ways to create hulls too.  It will help to dummy up a picture.
WilliamDochnahl
I do, but what I get is a line that crosses the track and jumps around a lot. If I can sort the points, I can get the line to travel along the correct path.
JoshuaBixby
Before focusing on sorting, you need to focus on attribution or grouping.  The screenshot looks to show vertices for 2 separate/distinct lines.  Is the data attributed in such a way that you can identify those 2 separate/distinct lines?  If not, then your first task is to find a way to group the points and then sort then.
WilliamDochnahl
These are all queried as "Unpaved Roads" in a much larger dataset. They are points taken along the side of this dirt road, but there is no other defining characteristic to sort the sides of the road, or to get them in any kind of order.
DanPatterson
