Group layer polygon creation
713
09-24-2024 01:45 PM
MitchGraham
I have divided feature classes in to group layers to make them toggle-able for better viewing. Upon creating polygons in the group layer (edit--> create-->polygon under correct group layer--> trace--> finish), the polygon is not appearing in the layer attribute table but is visible on the map. Rather it is somehow being created in a new layer titled ("group layer" (1)).
This new layer is not viewable (and thus not selectable) anywhere in the contents pane either.
I need to add all the field data in the attribute table for a complete polygon record but am unable to as the created poly is cannot be found in any attribute table.
Any help is appreciated. TIA.
version: 3.1.0
JenniferCadkin
Hi Mitch.  Can you share some screenshots of Pro?  Plus I have some questions...
Is the same feature class added to the map multiple times?  Do the layers have def queries, how did you 'divide' the feature classes into layers?
Jennifer
