Graphic Elements Disappearing while Zoom In
680
07-26-2024 12:46 AM
zsitompul
I draw lines and boxes in Graphic Elements (Graphic Layer), but the lines and boxes disappear if I change the symbolization or zoom in. I use the lines and boxes to help with Georeferencing. Is this a Bug?
TomBole
Hi @zsitompul
I'm unaware of any specific issue regarding the drawing of graphic layer features.  There may be an issue with the cache. Try clearing the cache and see if that solves the issue.
If you are still running into the problem I would treat it as a bug and contact support. They are better equipped to handle troubleshooting steps and gather bug data. They can be contacted at https://support.esri.com/en/contact-tech-support.
Hope this helps.
Tom
