Graphic and Text insert on the Layout Question
1408
12-16-2022 10:26 AM
DEAF_PROBERT_68
Honored Contributor
When I insert a text to create a text in the Layout under the Graphics and Text, my question to you is why does the text when you type gave too much space?  Here is the example:
When I type it and I didn't hit a space, but the problem is, it behaves that show it skips twice.
What is the solution for this ?
DEAF_PROBERT_68
Honored Contributor
Ok Problem solved!
Had to insert new layout and then copied and paste the graphic and text from the original layout....
Spent some time fix and correct in the new layout. When you are satisfied, copy and paste back to the original layout. If you need to correct it, fix it there...
See the screenshot:
Let me know if you need help. Some of you might have no problem with it or some of you might face issues that is one way to fix and correct in a new layout and experiment it..
DanPatterson
MVP Esteemed Contributor
it isn't wide enough to handle the text, stretch the right side and it will unwrap
... sort of retired...
DEAF_PROBERT_68
Honored Contributor
Ok Problem solved!
See the screenshot:
