'Ghost' line between polygons after merging
3098
02-10-2024 10:12 PM
HanliePetoors
I'm working on Windows 10, ArcGIS Pro 3.2.2 in a file gdb.
After merging two polygons I get this 'ghost' line between the two previous polygons. In the illustration below I have merged only one polygon.
When I identify or select I get the whole polygon but the ghost lines are still visible:
I've run repair geometry on the feature class but that fixed nothing.
Anyone come across this before? What do those ghost lines mean and how do I get rid of them?
Thanks
Hanlie
Tags (1)
MErikReedAugusta
MVP Regular Contributor
The first thing I can think to troubleshoot is to hit "Edit Vertices" and see what you get.
This almost looks like it's being stored as a multi-part polygon that happens to be contiguous.
Quick fix, you can delete the offending vertices if they are there.  But the bigger issue is likely in the base dataset: Did you allow multipart polygons?  Should you have?  Is there some other reproducible bug?
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
If this post or another helped you out, please consider giving the post(s) a Kudo or marking them as the Solution. ESRI Staff use both of these features to help keep track of posts on these forums.
MErikReedAugusta
M Reed
HanliePetoors
Hi @MErikReedAugusta ,
You're right, I could fix the problem by editing the vertices and deleting the ones that were causing the 'ghost' lines.
I think the original polygons had slight gaps or overlaps and that is what caused the problem. The original was supplied by a client and so I'm not in control of how they created that.
Good lesson for the future: check first for slivers/gaps!
Regards
Hanlie
