Getting Metes and Bounds from Lines or a Polygon
463
05-07-2025 09:21 AM
Labels (3)
Sky_3
Hi, I'm currently using ArcGIS Pro ver 3.1 with an advanced license. I recently was able to get metes and bounds from a polygon feature by converting it to a line feature, enabling COGO and then using the update COGO tool. However, the data would not export from the table with DMS as my units for the direction. I had to play around with the display for an hour or so to get the field to read correctly. Then once it was displaying correctly in the attribute table, it would still not export in that format. I tried the table to excel feature, then I tried exporting it as a dbf and a text file with still no luck. I ended up having to copy and paste it over in excel which is kind of tedious since it was roughly 200 points. Does anyone have any tips on how to quickly export this data? Or is there another simpler way to get the metes and bounds? I tried using the traverse tool, but the polygon I needed the metes and bounds from was the size of an entire town and the tool didn't seem like it was made for something that large. I also heard/read it's much easier to do this in Arc Map so maybe I'm missing something. Any help would be appreciated!!
DanPatterson
Convert Coordinate Notation (Data Management)—ArcGIS Pro | Documentation
might work it your data are in tabular format
... sort of retired...
