Get the full data path
3975
10-19-2021 11:36 PM
mody_buchbinder
In ArcMap when you point on any data in the catalog you can copy the full path from the "Location" at the top of the catalog.
This is very useful when you put the file path in scripts, work documents or emails.
I could not find an easy way to do it in Pro.
The best way is to drag the data into the python window - it put the full path.
You can drag it into the map and then open properties and copy the path and then the name.
When you point on the data you get a popup with the full path but you cannot copy it.
Any other idea?
Thanks
JayantaPoddar
I see. In catalog view, after selecting an object > Manage > Copy Path (see screenshot)
Think Location
JayantaPoddar
You could use Catalog View
Think Location
mody_buchbinder
Thanks for the answer but it gives the path without the dataset name. Please see screen shot from ArcMap.
Thanks
JayantaPoddar
Think Location
mody_buchbinder
They should put it for the catalog pane and not only view but this is fine too.
Thanks
