After defining the projecting of my .dwg using the define projection button in the Manage CAD layer tab the output is as shown in the attached image. As you can see the polyline features are in the top left corner however the centre of the feature is as shown by the yellow dot and border.
This makes scaling, rotating and position difficult. I wondered if this was a known issue or if it is something to do with my input .dwg?
If I use the CAD to geodatabase tool the issue is resolved. However I am then unable to use georeferencing to position the output, only scaling, rotate and move in the editing tab.
I am also having issues placing control points with this particular project, after placing 3 or so the option to place any further points is greyed out. Again is this an issue anyone else has encountered?
Thanks in advance.
