Geometry problem in 3D donut polygons
1018
03-26-2023 08:38 PM
MatthiasBoucher
Hello,
I'm facing a problem in ArcGIS Pro when I create a 3D polygon with a hole (donut), either with the geometric tools of the ribbon or with python code. I try to build donuts where the Z values of the inner ring (the hole) are constant, but lower than the Z values of the upper ring (like a cycling track or like a bathtub). Here in a 2D map everything seems fine, as we cannot see the Z.
But the problem is visible in a scene :
Everytime on two sides of the donut, some upper points are linked together with an edge :
Byt the way, this is not a display problem, as it persists after converting the polygon to different outputs (KML, Shapefile, etc).
I tried to reproduce this behaviour click by click with a more simple polygone, but still :
Is there a way to properly order the points so as to obtain a smooth slope without the 2 flat parts ?
GIS developer
