Generate tile cache tiling scheme error 000241
3413
7
10-16-2023 01:32 PM
Blevins_Mark
Im trying to generate a tile cache tiling scheme for an image collection in pro 3.1.3. Whenever i try, i recieve error 000241: "the specified path name or file type is invalid for the required input." I've tried tif, mosaic dataset, "raster" file types, nothing works. Anyone know why? Thanks.
GordonSumerling
@Blevins_Mark For Elevation We generally use the LERC compressed tile cache while for 3 Band RGB we use the mixed format (jpg & Png). This allows for transparency along the edges. Additionally, I can't see a coordinate system in your images.
If you are using WGS84 Web Mercator then I would suggest just using the Manage Tile Cache tool and Pick Elevation Tiling Scheme for the DSM and ArcGIS Online Tiling Scheme for the Ortho.  These then use LERC by default for Elevation and Mixed for the Ortho.
DanPatterson
MVP Esteemed Contributor
Can you provide the path name and file type and the input type?
... sort of retired...
Blevins_Mark
In the images below, you can see how it gives the error on the image file, but there is no error when i choose the dem file. Both are .tif files. Thank you.
Blevins_Mark
I think it was because i had the tile format set to LERC for the image, which i dont think is compatible with an image. Changing to one of the other formats gets rid of the error. Sorry, my oversight. Thanks.
GordonSumerling
Blevins_Mark
@GordonSumerling Thanks, that is pretty much what I did, except that my scene was a local one so I used a custom tile scheme so both the dem and image where in the same projection in the scene. Thanks, I received the error because I forgot to change the format from lerc to mixed on the image, so that was on me.
Blevins_Mark
@GordonSumerling actually do you know how i can get the image to not "extrude" the edges? Thanks.
Blevins_Mark
@GordonSumerling nevermind i found this and making the footprint of the image a bit smaller than the ground layer resolved the issue. thanks.
https://support.esri.com/en-us/bug/when-an-arcgis-pro-scene-with-a-custom-elevation-layer-bug-000138...
