Fonts different between RGB and CMYK exports?
2610
10
05-20-2022 08:08 AM
Joshua-Young
Is it expected behavior to have font and halo thickness change when switching between RGB and CMYK color models for a layout? The issue seems to only be with labels that have a halo applied to them. I tried using labels with no halos and I did not see any significant difference in the appearance of those labels.
I have attached examples of what I am seeing. RGB produces labels where the font is thicker and the halo thinner, whereas CMYK produces labels where the font is thinner and the halo thicker. I thought the color model only affected the colors?
"Not all those who wander are lost" ~ Tolkien
JeremyWright
I've tried quite few variables here and still can't repro the problem.  Would it be possible for you to send your repro case (for example a ppkx that contains a layout illustrating the probem) to https://support.esri.com/en/report-bug so we can start an investigation?
