Focal Statistics Majority Will Not Finish Running
1185
11-13-2024 12:37 PM
AliMulla
I am using ArcGIS Pro v. 3.2  (desktop). I have a raster layer of Aspect. I reassigned values into 9 classes to reflect direction (no aspect, N, NE, E, SE, S, SW, W, NW). I then converted this layer into Integer format using the Int. tool.
I am trying to run the focal statistics tool to display the majority value within a circular neighborhood of 100 cells (1000 m). The tool will start to run, and then get stuck on 100%. No error messages, no warnings, etc. I've tried this a few times, and have waited over 2 hours on one occasion. Eventually, I just have to re-start the program.
Has anyone else run into this issue? Any troubleshooting advice?
Thank you,
Ali Mulla
Ed_
by MVP Regular Contributor
maybe see if restarting your computer helps
maybe clearing ArcGIS Pro cache (under Project > Options > Display) helps
maybe save the raster in your geodatabase or if that doesn't work then save it outside the geodatabase and into your local drive (not OneDrive or Google Drive)
Question | Analyze | Visualize
MonicaWilkinson
Did you by chance figure out a solution? I'm having this exact issue now.
