Finding unsnapped features
812
12-02-2025 09:25 AM
FSD_Main
Just curious if there is a way to find and fix lines not snapped to points without having a Standard or Basic license?
TY
JenniferCadkin
For visual inspection, you can try using Vertices and Nodes capability to see where unsnapped points are located- in Vertices and Nodes, they are called 'Isolated Points'.    Vertices and Nodes is available with ArcGIS Pro 3.5 and later.
https://pro.arcgis.com/en/pro-app/3.5/help/editing/symbolize-vertices-and-nodes.htm
https://pro.arcgis.com/en/pro-app/3.5/help/editing/change-vertices-and-nodes-settings.htm
RPGIS
by MVP Regular Contributor
There is but it may require some knowledge of either arcade or python in order to find unsnapped points. The other thing to try is to set a location filter for all the points and finding the nearest line where the distance is greater than 0.
JenniferCadkin
FSD_Main
Great! This is perfect. Thank you
