Find and delete Carriage returns
3631
6
11-11-2021 03:29 AM
IFI
I am working with a Feature Service created from a Survey123 form.
Some of the users have inadvertently added carriage returns in their answers.
Is there a way to find the carriage returns and delete them, either using Find and Replace or a Field Calculator expression?
Paul
MichaelVolz
Esteemed Contributor
Aldo:
Did you run this code in the field calculator or a standalone python script?
Robert_LeClair
Esri Notable Contributor
There's a related thread here that adds a constraint to prevent survey responses from having trailing "whitespace" or "carriage returns" that seems to also prevent this from occurring in the middle of the response as well.  To remove extra spaces on existing attribute values using Arcade, there's a related thread here.  Good luck!
IFI
Hi Robert,
Thanks for that! I still need to figure out a way of removing the carriage returns in bulk!
Paul
JoshuaBixby
It isn't pretty, but it is simple to implement.  You can use a chained Python string replace call:
>>> s = "NRSP21_Rose Court_A\r\n_1_211012_162927447_16"
>>> print(s)
NRSP21_Rose Court_A
>>> s_new = s.replace("\r", "").replace("\n", "")
>>> print(s_new)
NRSP21_Rose Court_A_1_211012_162927447_16
IFI
Hi Joshua,
Thanks for the reply. I guess I could implement that in a Field Calculator Expression?
Also, this replaces the carriage return (and space if I'm reading it correctly) for that particular row only, is that right? I would need a more complicated expression to find and replace them in a number of rows?
Paul
Aldo_
Not sure if OP has already found a solution for multiple rows, but I had the same issue. Difference is I am dealing with a feature class - not hosted feature layer - with over 311,000 rows. Below is what I did in Pro to remove the carriage return and new line in one field of a feature class.
Note that I had to deal with thousands of nulls, which my first if statement identifies them as either None, no space, and single space, and then does nothing to it.
Then, instead of replacing "\r" and "\n", I have to use its respective chr() method, following @JoshuaBixby's replace function (thanks Joshua!)
Run time was about 2 minutes.
with arcpy.da.UpdateCursor("layerName","fieldName") as cursor:
        for row in cursor:
            if row[0] in (None,""," ","Anything-Else-To-Avoid"):
            else:
                row[0] = row[0].replace(chr(13),"").replace(chr(10),"")
                #if you wanted visual confirm use print(row[0])
                cursor.updateRow(row)
MichaelVolz
Aldo:
