Fill tool taking forever to complete
1495
01-20-2025 09:16 AM
MdOmerHossain
Hi, I was trying to run a fill tool to 10 m cell size DEM layer. While initially it runs fast then after a certain time it stuck in 83% processing time. It runs fast up to 83 % then totally stuck in 83%. I kept it running overnight but still it's showing 83% processed. What is the reason?. The DEM layer was previously 2.5 feet cell size which I resampled to 10m. Even in 2.5 feet it was completed within an hour but with 10m cell size it's taking that much time without any progress after 83%. I cancelled the tool, restarted the computer and again run the tool. But still, it is stuck at 83% processing.
DanPatterson
Fill (Spatial Analyst)—ArcGIS Pro | Documentation
There are lots of things that can affect performance.
Running Sink, as suggested in the help might be worth while before proceeding to Fill so you can examine the Sink results.
Resampling can create issues
Resample—ArcGIS Pro | Documentation
what methods have you tried?
... sort of retired...
MdOmerHossain
Thank you for responding. I tried sink tool before running the Fill too. It also was taking forever to complete the sink tool. Then I had to cancel the sink tool (see history).
In the case of resampling, I used previously filled DEM which was 2.5 feet. Since I resample the DEM, I was thinking I have to fill the sinks. Is using already filled DEM creating this problem? I used nearest Neighbour technique for resampling. I checked the tool now, it's still stuck in 83%.
DanPatterson
If you tried the sink already and it is cutting out at 83% again, I would clip a portion of the raster to see if you can get a smaller area to complete.
You should indicate the size of the raster.  It may be that you are just running out of memory and every step is being written out to disk which is going to painfully slow down the progress.
Otherwise... off to Tech Support so they can get the information from you that would be needed to resolve your specific situation.
GerhardMaree1
In general all the terrain processing tools have been a hassle to use in ArcGIS pro since 2.4 currently on 2.5.  I just opt to go directly to ArcGIS Desktop 10.8.2  and it actually finish processing.  Fill tool in ArcPro stuck on 44% for days now and the same dataset completed within 5min on ArcMap. Mind begogeling that it can go so backwards.   Its not like you dont pay a premium for the latest software ...
