Field values in attribute table changing
790
06-25-2024 08:30 PM
Labels (2)
nomit
I am editing values in the attribute table in arcgis pro for the "ar_flrArea" field FID 348 and 1306. When i save the edits the field values for "flr_grnd" and "tot_flr_ar" automatically change. Attaching the screenshot below.
Screenshot before
Screenshot after
Why are values changing?
This is also happening when i set up an update cursor on the table. Without causing any change to the flr_grnd and tot_flr_ar.
Will try to provide as much information about the data:
1. It is a shapefile
2. The data type for the fields "flr_grnd" and "tot_flr_ar" is float. With both the fields having zero precision.
3. Using windows 11 pro.
Let me know if sharing any other details would help.
