Field is not Nullable Error (Calculate Field)
2100
11-03-2020 08:10 AM
MatthewMcMillan1
Hi all,
I am trying to populate a column 'Residentia' with YES or NO based on if another column (AllDetails) contains certain text.
When I run the below code, it gives me a 'Field is not nullable Error'
Can anyone advise?
Thanks!
DavidPike
MVP Notable Contributor
if "rezone" in field:
    result = "YES"
else:
    result = "NO"
return result
DavidPike
    result = "YES"
else:
    result = "NO"
return result
MatthewMcMillan1
David, thank you again!
