I am trying to use the field calculator to concatenate various fields into one new field. The ArcGIS Arcade Guide gives the following example
Concatenate(['red', 'blue', 'green'], '/')
which gives red/blue/green. This works fine when all of the fields contain a value, but how can i concatenate only the fields that are not null
I am trying to concatenate address details , so for example
field1 = building name
field2 = building number
field3 = road name
field4 = area
field5 = town
in my example the building name or area could be null, so i end up with:-
,12,A Road,,Town - so i need to remove the additional field separators ','
Thanks for any help
Solved! Go to Solution.
Not sure how it could get much simpler. If the passing of field names is removed, the code boils down to:
', '.join([str(i) for i in [ ] if i])
That is pretty simple and compact. The bulk of the line is in field names, and you can't remove them.
I know this thread is old, but in case anyone comes across this searching for this solution as I did, I got the code to work by replacing the full quotes "" with single quotes '' on line 17 when used in an AGOL custom field
