FGDB database view — Join fields missing from attribute table
1743
01-19-2024 06:29 AM
Bud
Legendary Contributor
ArcGIS Pro 3.2.1; file geodatabase
Background:
Here is a SQL query for creating a database view called species_records_latest_vw:
select
from
    species_records
left outer join
    (select
        t_species,
        max(t_date) as t_date
    from
        species_records
    group by
        t_species) l
    on species_records.t_species = l.t_species
       and species_records.t_date = l.t_date
Oracle 18c 10.7.1 EGDB:
If I try to create a view using the above SQL in Oracle, I'll get an error due to joined/duplicate column names. I won't be able to create the view. That's expected.
ORA-00957: duplicate column name
Mobile Geodatabase
I can create a view using the SQL in a Mobile Geodatabase without errors. The joined/duplicate columns are included in the attribute table. The duplicate fields are suffixed with ":1", making them unique. That's a valid way of handling the duplicate fields.
File Geodatabase
I can create a view using the SQL in a File Geodatabase without errors. However, the joined/duplicate columns have been excluded from the attribute table. That's not expected.
03528630 - ArcGIS Pro 3.2.1: FGDB database view has joined fields with duplicate names; joined fields should not be excluded from attribute table
BUG-000164420: Database View created in file geodatabase with Join definition does not create the required duplicate fields
Question:
The FGDB view should either behave like the Oracle view (throw an error) or behave like the Mobile GDB view (include the fields). But it doesn't do either of those things. It excludes the joined fields which defeats the purpose of the join and the view.
Are there any workarounds for this issue?
Bud
Instead of using SELECT * for both tables at the same time, use a SELECT * for each table separately:
select
    s.*,
    l.*
from
    species_records s
left outer join
    (select
        t_species,
    from
        species_records
    group by
        t_species) l
    on s.t_species = l.t_species
       and s.t_date = l.t_date
That seems to force the attribute table to use the table alias from the query as a prefix, making the field names unique in the attribute table.
Bud
select
    s.*,
    l.*
from
    species_records s
left outer join
    (select
        t_species,
    from
        species_records
    group by
        t_species) l
