FeatureClassToFeatureClass attribute tables are blank
1137
05-20-2021 06:01 AM
dlund203
I'm creating a script tool where I want to create a number of point/polygon shapefiles, then convert them to geodatabase feature classes in the current workspace. The shapefiles are generated correctly, but the GDB feature classes have blank attribute tables, with only the attribute labels populating.
Here's the relevant part of my script:
class Run:
    def __init__(self, file, run_id):
        self.gdb = arcpy.GetParameter(0)
        # other stuff
    def get_fc(self):
        c_feats = []
        for c in self.crafts:
            shape = self.new_aircraft(c)  # shapefile
            c_feat = arcpy.conversion.FeatureClassToFeatureClass(shape,
        self.gdb, c.id)
            c_feat_name = str(c_feat)
            c_feats.append(c_feat_name)
        arcpy.SetParameterAsText(3, ';'.join(c_feats))
Tags (3)
DavinWalker2
With missing code (#other stuff) it's a little hard to know exactly was is happening.
