Feature Layer inconsistently not editable in arcGIS Pro, only in Arcgis Online
3297
07-02-2024 02:49 PM
Labels (2)
wabritton
A online hosted feature layer is editable online but not in the desktop arcGIS Pro.  The layer is used for polygons.  I can create two polygons, then I can't edit them or delete them.  And at that point I can't create any more polygons either.  "Failed to create.  Layer is not editable"  And for polygons that can't be deleted with error: "Delete selected features failed.  Layer is not editable."  Sometimes the polygons can be edited, but when the edits are then saved there is a "save edits failed. General function failure [Error code:1500. Description: Incorrect geometry type...] and the edits are undone and the polygons reverted.
But these newly created polygons which are not able to be deleted/edited in arcGIS Pro can be deleted/edited online in the map viewer.  I have checked and the layer is set to be editable online.
Georgios-NektariosTselos
Hello @wabritton ,
First of all use the Repair Geometry tool.
The Check Geometry tool generates a report of all features with geometry problems in the feature classes. To fix these problems.
Then if this tool doesn't work, try the next directions and i think these will be work
First, i suggest to test this - copy the data to a local file geodatabase.Then add the data to a map in a new project and try to open . Does the error continue to exist? If not, then maybe there's something with the settings for the network drive.
Also you can check these links maybe you will find useful
https://pro.arcgis.com/en/pro-app/latest/help/data/validating-data/invalid-geometry.htm
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/checking-and-repairing-geome...
Best Regards
Georgios-Nektarios Tselos
wabritton
If the data is copied to a local file the issue goes away and the polygons can be created, edited, and saved as normal.  Like I said the online layer is set to be editable and no settings have been changed, so I don't know what could be causing this although I agree it seems to be with the online feature.
MdeBoer
Hi @wabritton , it seems to me that you have encountered this bug: https://support.esri.com/en-us/bug/in-arcgis-pro-creating-ellipsoid-or-freehand-features-o-bug-00017.... The workaround is as suggested earlier, save the data in a local geodatabase, make your edits, and republish the layer.
Best,
Menno
philnagel
We are also experiencing this issue, with true curve geometries in a line layer. Thanks for posting the bug! In our case, we are able to use the offline sync in Pro to edit these features as a workaround. This is likely a better option then overwriting the service to edit features.
