Feature class to geodatabase removes global id
668
02-26-2024 08:28 AM
Scosh
I'm using arcpy.conversion.FeatureClassToGeodatabase() and it removes the globalid field. This doesn't happen when I manually copy a feature class to a new gdb. Is this a bug or am I missing something?
JakeSkinner
Esri Esteemed Contributor
Hi @Scosh ,
I'm not sure if this is by design or not, but you can use the Export Features tool to workaround this.  There is an environment setting to preserve existing GlobalIDs:
You can also right-click on the tool to execute it in Batch to process multiple feature classes.
