Feature Class Editing ArcGIS Pro
1559
09-08-2017 01:16 AM
ClaireLauder1
Has anyone had issues with Feature Class corruption while editing in ArcGIS Pro?
DanPatterson_Retired
No.  You will need to explain your work situation. Is this locally stored data? Type? What you were editing? etc
ClaireLauder1
I was editing a Feature Class dataset and the file corrupted and I couldn't open. When trying to fix the issue the whole Feature Dataset completely disappeared out of the GDB.
ClaireLauder1
Locally stored data: yes
Edits: adding a field and deleting a field.
Nothing out of the ordinary. I don't suppose that you can replicate the issue.  You would also need to specify how you were trying to 'fix it'.  As for adding then deleting a field, at any time before, during or after did you Save that step?
If this happens again and was not a one-off on a particular file, then you will need to contact tech support so they can isolate the source of the problem
