Feature class alignment issue in Arcgis Pro.
939
01-19-2026 02:53 PM
RobertFaison
Several months back, I created a project to lay out burial plots in a church cemetery.  I have no formal training in GIS, and I'm self-taught.  Not knowing better at the time, I created several feature classes and didn't pay much attention to coordinates when I set them up, but nonetheless, I did create a pretty nice and extensive cemetery project, and it all looked pretty good.
This Friday, I decided to share the project as a Web Map, so other members of our church could view the maps.  In the process of uploading, I ran into issues because the coordinates used on a couple of feature classes were not the same as the Background Map, so I started making changes in the coordinates used in those feature classes.
At this point, everything blew up when viewing the project on screen, and after much difficulty, I was able to locate most of the feature classes at the prime meridian and equator and change them back, but the main feature class (burial plots) that took me days to create now does not line up with the rest of the map.  It's close but several yards off.  I have tried using every coordinate system I can locate, but I still can't get it to line up.  I would appreciate any suggestions.  Thank you in advance.
DanPatterson
MVP Esteemed Contributor
featureclasses need a defined coordinate system, so if it was not defined, or more importantly, defined wrong, then you need to define it correctly using
Define Projection (Data Management)—ArcGIS Pro | Documentation
Once defined correctly and you want it in another coordinate system, you need to use this tool
Project (Data Management)—ArcGIS Pro | Documentation
So "define" correctly, then "project" to get it into something else. You can substitute or change the order and "defining" something that is defined incorrectly doesn't work
... sort of retired...
LindsayRaabe_FPCWA
MVP Regular Contributor
Also, once you have got your coordinate system setup correctly, if you still need to move your data to sit in the correct place (due to it being created in a the "wrong" place originally based on an incorrect coordinate system) you can select all your features and move them manually.
Move, rotate, or scale features—ArcGIS Pro | Documentation
By moving them all at the same time, hopefully they will maintain their spatial integrity in relation to each other and still fit the site they belong to. If needed, you have the Scale option (same link above) to resize everything equivalently.
I don't know what coordinate system you settled on using, but when we're publishing to ArcGIS Online, we default to the Web Mercator Auxillary Sphere to keep it all simple and like for like (as that what AGOL uses in the webmaps).
Lindsay Raabe
GIS Officer
Forest Products Commission WA
RichardDaniels
The consistent offset you are seeing is often a result in (1) wrong datum selected (WGS80, NAD83, NAD27) or (2) error in the source layer you digitized 'from' (i.e., all data in GIS has an error, even fancy imagery from ESRI).
Since you say you are a novice, I would ask how did you MAP the plots? Did you use a GPS device to map the boundary or did you just use editing tools in ArcGIS Pro to map the plot locations from air photography of some sort. Why is this important? If you used GPS you need to know the DATUM that your receiver used when you collected the data. This is a key parameter used when initially defining the coordinate system used for the feature layer. Secondly, if you digitized the boundaries from air photography/orthomosiac in ArcGIS Pro, then a similar question arises about the datum/coordinate systems used in the photography.
Last thought, unless you used a submeter GPS device to collect the plot locations you should not expect plots to align 'perfectly' with any 'free' imagery provided by ESRI (since the free imagery has error as well). You need to identify 'which' layer has the best accuracy and compare everything 'else' to that.
