Failed to save project Arcgis pro 3.4.0
558
01-27-2025 02:51 PM
lien1
Hi all,
I am using Arcgis Pro 3.4.0. I am unable to save either the existing project or new project. The error message is ' Failed to save project to 'C:\Projects\test.aprx'.
I tried to create a new project based on this linked https://pro.arcgis.com/en/pro-app/latest/get-started/create-a-project.htm and save the project but it has error above.
Please help me how to overcome this error.
Tags (1)
DanPatterson
MVP Esteemed Contributor
When you created a new project, did it get created in the C:\Projects folder?
Did you try a "save as" and specify a folder that you know exists?
... sort of retired...
lien1
Hi DanPatterson,
I generated a new project and then load the shapefile into the contents and save to the project generated. I attached the powerpoint which screenshot steps I did and error message.
Cheers,
Lien
DanPatterson
"Save Project As"  to save to a new location
and while you are at it, give it a new name
