I initially created a new database on our MS SQL server and enabled the database through AGP 3.0 as an enterprise database.
Thereafter, I populated the database with data tables. Each table contains a primary key, where 'Not Null', and 'Identity' are set to true. Since a primary key implies a unique index I think the solution from this posting does not work for me.
The 'solution' for the issue at hand on this page is also very 'precise' and I do not know why my tables cannot be shown in a table view.
What I can see in the monitor is
<Event time="ti aug 16 15:02:00.034" type="Error" thread="5938: Main CIM worker thread" elapsed="0" function="" code="">
Cannot convert OID 4711880873618702336 to 32-bit integer.
</Event>
My database table does not contain a column named 'OID' and within the entire table a value of 4711880873618702336 cannot be found.
The primary key of the table is called idq_id and has a max value of 11,321,131, while the table contains a total of 2,480,912 rows
One more thing, using the 'XY Table To Point' tool I was able to create a point FC of more than 5 million points without any problem, and I can visualize the attribute values of the FC. However, opening the database table fails to retrieve the page of rows.
I would really appreciate suggestions on how to solve this issue.
- We are living in the 21st century.
GIS moved on and nobody needs a format consisting out of at least three files! No, nobody needs shapefiles, not even for the sake of an exchange format. Folks, use GeoPackage to exchange data with other GIS!
