Failed to add data.
12680
08-09-2017 11:06 AM
RadoslawCylwik
I'm having issues adding data to my ArcGIS Pro map.  All the data works perfectly fine when brought over to ArcMap.  One of the tables has a geometry field calculated in SQL.  Another table has a geometry field and an assigned ObjectID field.  Both tables are in a regular database table.
AdrianWelsh
MVP Honored Contributor
Radoslaw,
Can you elaborate more on the problems you are having? Is there an error message? Can you post a screen shot?
Ahmed_AltafTambe
68026rc‌ : Could you confirm the following:
- Does the tables have any column which does not allow NULL values?
- Try to add the tables using ArcGIS Pro 1.4.x, is the issue still encountered?
