Can you have overlapping symbols merge and show how many symbols merged
917
10-11-2017 11:34 AM
TomDeBaun1
I want to set up a map with point data where when a number of points overlap they merge into a larger symbol that is labeled with the number of points that merged together. Ideally when you zoom in on that point the points un-merge and show normally. I've seen maps that do this online a few time so I know it's possible to do. Is there a simple tool to do this or is this something I will need to set up on a case by case basis within a map as I go? Is this something that I would have code? I currently use ArcGIS Pro 2.0, but I have access to ArcMap if I need it
