Fail to import a feature to Postgresql database via Arcgis Pro
5391
5
02-25-2022 07:38 AM
Labels (3)
IB3
Hi everyone,
I am getting this error message when I try to import a feature to my Postgresql database via ArcGIS Pro.  ERROR 000210: Cannot create output...
Has anyone had this problem before?
Isabelle
JayantaPoddar
MVP Alum
Rename the sde connection file to start with an alpabet. Also could you copy the SDE file to a shorter, non-OneDrive path with no space or special characters in pathname.
e.g.:
D:\GreenDestinations\CSM5432.sde
Think Location
IB3
@JayantaPoddar Hi again, I have tried everything and still get this message. Does anyone else had this problem before? Thanks
IB3
@JayantaPoddar Thank you for your message. I have tried it and it still doesn't work.
moremeowbell
I'm having this issue as well... Has anyone found a resolution?
Jennifer Pramuk MGIS, GISP
KumbiraiMatingo
@IB3 and @moremeowbell or if anyone else is still facing this challenge like I did just now. I found this resource to be very helpful. You can take a look at this here - https://pro.arcgis.com/en/pro-app/latest/help/data/databases/add-the-st-geometry-type-to-a-postgresq...
This solved my issue. Apparently, ArcGIS requires some special permission in the DB.
