Fail to classify pixels using deep learning with GPU
2136
06-22-2023 05:55 AM
XISHI
When I run the toolbox "Classify pixels using deep learning" with the CPU, everything seems fine, except that it runs extremely slow. So I tried to run it with the GPU and got multiple failures::
ExecuteError: ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Parallel processing job timed out [Failed to generate table]
Failed to execute (DetectObjectsUsingDeepLearning).
The parameters and environments were set as below:
Then I further try it in the Python command line with:
with arcpy.EnvManager(processorType="GPU"):
out_classified_raster = arcpy.ia.ClassifyPixelsUsingDeepLearning("setnul_raste", r"E:\Z_Phd_Other_stuff\2023_06_21_jx\jx\MyProject\model_unet2\model_unet2.dlpk", "padding 0;batch_size 32;predict_background False;test_time_augmentation False;tile_size 224", "PROCESS_AS_MOSAICKED_IMAGE", None); out_classified_raster.save(r"E:\Z_Phd_Other_stuff\2023_06_21_jx\jx\MyProject\MyProject.gdb\setnul_raste_ClassifyPixelsU3")
The same error occurred:
File "<string>", line 2, in <module>
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\ia\Functions.py", line 2206, in DetectObjectsUsingDeepLearning
return Wrapper(
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\sa\Utils.py", line 55, in swapper
result = wrapper(*args, **kwargs)
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\ia\Functions.py", line 2195, in Wrapper
result = arcpy.gp.DetectObjectsUsingDeepLearning_ia(
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
My PC has an AMD 7950X CPU and RTX 4090 (GPU0) and the version of ArcGIS Pro is 3.0.1. Is there any solution or suggestion?
XISHI
Or anything I missed?
JesseCloutier
Esri Community Manager
@XISHI, I've moved this post from our Community Feedback area to the ArcGIS Pro Questions Board, where it's more likely to be seen and responded to by members with relevant expertise. All the best!
Jesse Cloutier
Community Manager, Engagement & Content
PavanYadav
@XISHI
Have you been able to fix it? Your nividia GPU should work. just for a test can you please try a smaller batch size e.g. 2 or 4? Are you running the tool within ArcGIS Pro or from a script?
Cheers!
Pavan Yadav | Product Engineer - Imagery and AI
Esri | 380 New York | Redlands, 92373 | USA
https://www.linkedin.com/in/pavan-yadav-1846606/
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
Kaifichomani
Same problem here and not fixed yet.
I used ArcGIS pro 3.4 and classify pixels using deep learning. Training the model was successful but when I choose to test the same model, the GPU is not working. I have RTX4060.
