Extract values to point from multiple raster with time property
2241
03-17-2025 05:20 AM
Pva013
Hi, i have multiple rasters of VCI (Vegetation Condition Index) from 1/12/2019 to 31/12/2022 (from December to June) with 16 days interval reset at 01/01 of each year like this image
I also have a set of points with date like this.
I want to extract values to point but with the exact time period (Ex: VCI raster from 1/1/2020 to 17/1/2020 extract to points have date in that period like 5/1/2020). I tried to create a mosaic dataset then set time property and date field to it but after that i have no idea how to continue. It would be great if anyone have other solution to the problem.
Thanks in advance
AustinAverill
I would say the best way to do this would probably be to iterate through the rasters and read in the date period from the name using python. You could then do a selectByAttribute within the loop and then extract values based on that selection. It would look something like this.
import arcpy
from datetime import datetime
arcpy.env.workspace = "path\\to\\fgdb\\with\\rasters"
points = "path\\to\\points"
rasters = arcpy.ListRasters()
for i in range(len(rasters)):
    while i < len(rasters) - 1:
        start_date_str = raster[i].name.replace("VCI_VCI_", "")
        end_date_str = raster[i+1].name.replace("VCI_VCI_, "")
        start_date_format = "%d_%m_%Y"
        final_date_format = "%Y_%m_%d"
        start_date = datetime.strptime(start_date_str, start_date_format).strftime(final_date_format)
        end_date = datetime.strptrime(end_date_str, start_date_format).strftime(final_date_format)
        q_str = f"'ACQ_DATE' >= date '{start_date}' AND 'ACQ_DATE' < date '{end_date}'"
        selection = arcpy.management.SelectLayerByAttribute(points, "NEW_SELECTION", q_str)
        arcpy.sa.ExtractMultiValuesToPoints(selection, rasters[i])
This might not be the perfect example, but should get you going in the right direction.
MervynLotter
MVP Regular Contributor
After creating your raster mosaic, the next step would be to create a multidimensional layer using the "Make Multidimensional Raster Layer" GP tool. You will them have a set of multidimensional raster tools available to explore your data and extract the necessary information.
See Multidimensional raster data—ArcGIS Pro | Documentation
AustinAverill
import arcpy
Pva013
Thanks for your idea. Here the code for anyone interest in this problem. Im not 100% sure it right but it work for me anyone have better idea or more accurate code please share i really apprieciate it.
import rasterio
import geopandas as gpd
import pandas as pd
import numpy as np
import glob
import os
from datetime import datetime, timedelta
points_gdf = gpd.read_file('C:/Users/Admin/Desktop/W1/point1.shp')  # Adjust path as needed
points_gdf['date'] = pd.to_datetime(points_gdf['ACQ_DATE'])  # Replace 'date_column' with your actual column name
def extract_date_from_filename(filename):
    # Extract date components from filename like "VCI_VCI_2020_02_18.tif"
    parts = filename.split('_')
    if len(parts) >= 5:
        year = int(parts[2])
        month = int(parts[3])
        day = int(parts[4].split('.')[0])
        return datetime(year, month, day)
    return None
def extract_vci_by_date(raster_files, points_gdf):
    results = points_gdf.copy()
    results['vci_value'] = np.nan
    raster_periods = {}
    for raster_file in raster_files:
        filename = os.path.basename(raster_file)
        date = extract_date_from_filename(filename)
        if date:
            end_date = date + timedelta(days=15)
            raster_periods[raster_file] = (date, end_date)
    for idx, point in points_gdf.iterrows():
        point_date = point['date']
        for raster_file, (start_date, end_date) in raster_periods.items():
            if start_date <= point_date <= end_date:
                with rasterio.open(raster_file) as src:
                    x, y = point.geometry.x, point.geometry.y
                    try:
                        row, col = src.index(x, y)
                        value = src.read(1, window=((row, row+1), (col, col+1)))
                        results.loc[idx, 'vci_value'] = value[0][0]
                    except:
                        continue
                break
    return results
raster_files = glob.glob("C:/Users/Admin/Desktop/W1/VCI/VCI_VCI_*.tif")  # Adjust path as needed
results = extract_vci_by_date(raster_files, points_gdf)
results.to_file("vci_extraction_results.shp")
