Presence-only Prediction (MaxEnt) geoprocessing tool
1032
02-20-2025 09:21 AM
Labels (3)
KerryBillington
Predict seagrass habitats with machine learning tutorial
https://learn.arcgis.com/en/projects/predict-seagrass-habitats-with-machine-learning/
I encountered an issue while following a tutorial in ArcGIS Pro 3.4. The Presence-only Prediction (MaxEnt) geoprocessing tool failed to execute, returning the error:
Error 110202: Problem parsing Explanatory Raster datasets.
However, when I ran the same tutorial on my work computer with ArcGIS Pro 3.3, the tool executed successfully without any errors.
I’m looking for a workaround to resolve this issue so I can guide students on how to address it. Any insights or solutions would be greatly appreciated.
Bahram
Same here. I have sets of GIS files that used to work without any problem in ArcGIS Pro 3.3. Now I am using ArcGIS Pro 3.4.0 and same files and same procedures gives me this error:
MaurizioBiondi1
Hi everyone, in my experience I saw that this problem depends on the 3.4 update. In fact, with ArcGis Pro 3.3 "Presence-only Prediction" works without problems while it gives the error 110202 with 3.4.
Other people have encountered this problem: https://community.esri.com/t5/arcgis-pro-questions/presence-only-prediction-maxent-geoprocessing-too...
MaurizioBiondi1
JesseCloutier
Esri Community Manager
Hi @Bahram  and @KerryBillington, we appreciate you sharing a potential bug with the broader Esri Community. Please keep in mind that Esri does not actively track software defects posted here. The official channel for investigating and validating bugs is Esri Technical Support. All customers experiencing a potential software bug should leverage technical support to report and investigate the issue.
By reporting bugs through technical support, Esri can better track the scope and impact of the issue across all our customers and better prioritize it with our product teams. Our teams can also investigate the issue more thoroughly to see if there is a solution, workaround, or patch to get you back up and running as soon as possible.
As a reminder, Esri Community is primarily a self-service support platform where Esri users can ask or answer each other’s questions, share feature requests, and collaborate to solve problems with GIS.
*Note that this is a scripted message prompted when posts allude to a potential product bug.
Jesse Cloutier
Community Manager, Engagement & Content
