Presence-only Prediction (MaxEnt) (Spatial Statistics)—ArcGIS Pro | Documentation
Allow Predictions Outside of Data Ranges
(Optional)
is this checked or unchecked?
at least one web post had the error message when the default was used, so try unchecked...
Unchecked—The prediction will not allow extrapolation beyond the range of values used in training.
You can worry about why after.
Hi @DanPatterson, thank you for the suggestion! I tried running the model with the Allow Predictions Outside of Data Ranges both checked and unchecked, but the error still showed up.
There could be some reasons for this error
Hi @DanielFox1, thank you for your suggestions! I've ensured that the extents, coordinate systems, and resolutions are all aligned and there are no NoData values in the rasters.
The Presence-Only Prediction tool works without background points. For my purposes, I would like to have background points included because I have verified specific locations as background points within my data. Is there a way to work around this issue?
Hi everyone, in my experience I saw that this problem depends on the 3.4 update. In fact, with ArcGis Pro 3.3 "Presence-only Prediction" works without problems while it gives the error 110202 with 3.4.
Other people have encountered this problem: https://community.esri.com/t5/arcgis-pro-questions/presence-only-prediction-maxent-geoprocessing-too...
Hi all, I was getting the same Error: 110202 when running MaxEnt on 3.4.0. I just updated Pro to 3.4.3 and the tool completed without the error.
Edit: Nevermind - it decided to start failing on me again with the same error message. I haven't changed the data or settings.
