Extract polygons that overlay with a circle
1299
06-19-2024 08:54 PM
cskari
Hi All
I overlaid a grid circle (shapefile) on an administrative area shapefile.
I want to extract all polygons fully or partly overlaid with this circle (i want to retain all polygons that are in the margin of the circle if a small part of the polygon comes inside the circle).
I would be grateful if somebody could suggest a tool that I can use for this, please.
Many thanks
DanPatterson
MVP Esteemed Contributor
Select Layer By Location (Data Management)—ArcGIS Pro | Documentation
didn't work?  use the circle to select the polygon layer with Intersect most likely
... sort of retired...
DanPatterson
