Extract Multipatch from Mesh (3D Analyst) Tool
2040
02-05-2024 03:04 AM
sevinc4maps
I'm trying to use Extract Multipatch From Mesh. I have an slpk mesh file. At the same time, it asks me to add a footprint. I select both, and when I run it, I don't get an error, but I get an empty output. What could be the reason, Why am I not getting any results?
Thanks in advance
Andrew--Johnson
Can you run the slpk through the validate scene layer tool and report back if it returns any errors? If the slpk comes from a 3rd party that doesn't adhere to the i3s specification then there could be unexpected results when running data management tools.
thanks,
Andrew
sevinc4maps
I get this type error.
Andrew--Johnson
Ok looks like just a warning so that should not impact the output of the tool. You could try sketching one polygon footprint on the mesh and running the tool to see if it's an issue with the footprint polygon. Otherwise if you want to share the slpk I can take a look too.
thanks,
Andrew
ErilennyAbreu
Hello,
I'm having the same issue, how did you resolve it? .
