Expression Query not reliable
1458
11-03-2021 02:40 PM
SujanShrestha
Something weird is going on with ArcGIS Pro. When build a expression in "Select by Attribute", the selection set keeps reverting back to the older/previous query, or the Value field becomes empty, erasing the options I selected. This is a real pain and a major source of data error. This even happens in the Def Queries I build.
Would appreciate any help!
jcarlson
Sounds like a bug, honestly. If you switch the query to SQL, is that also showing the previous value? I would attempt writing/modifying your query in SQL to see if it performs differently, to see if the issue is just with the clause builder, or the definition queries in general.
- Josh Carlson
Kendall County GIS
SujanShrestha
Thanks for the reply Josh. Once I build the expression and switch to SQL, it does show the previous value. But, the error does not happen when I build the expression in SQL.
