Exporting PNG image with background transparency from ArcGIS Pro
17607
12
07-20-2016 10:39 AM
MichaelSchoelen2
I am attempting to export a PNG image file from ArcGIS Pro 1.2.0 with the background set to transparent. In ArcMap 10.3 this is simple, there was a button for setting the transparent color to white during the export.
When I go to "share" the image in ArcGIS Pro, I do not see the same options to set my background or transparent color. Has this button been moved elsewhere? Or is it not an option anymore?
DanPatterson_Retired
ConnorHouston2
I have the same issue with transparency. The map itself hounors the transparent background when sharing as PNG - 32-bit with Alpha. However the layout does not honour the transparent background and exports the blank page as white.
AdrianWelsh
MVP Honored Contributor
Connor,
Where are you obtaining the image from? I have found that using a WMS gives me a blank background when exported. But, if I use WMTS, the background is not blank.
ConnorHouston2
There are no WMS services. The layout has a single shapefile. The area around the layer (blank space) in the layout should be transparent when shared as PNG, not with a white background.
AdrianWelsh
Oh, I get it now. I misunderstood earlier. I am not sure that exporting to a PNG in Pro will have this effect. I feel like it will act the same as a jpg or other file format and not obey the PNG rules like you see with most PNGs. I hope I am wrong though.
MichaelSchoelen2
To clarify, I'm using ArcGIS Pro 1.2. When I export (or share) as a png image from the map view, the background is exported as transparent. However (more importantly) when I export from the layout view, and I "share" as a PNG, there is no option to set transparency, like in ArcMap. Is this something that was added in a later version of ArcGIS Pro?
On stack exchange, it was determined that " ArcGIS Pro does not currently support exporting with transparency in the Layout. "
MichaelSkipper
This is a problem that needs to be fixed.
MichaelSkipper
I would like to set the transparent color to be something other than white.  We often use masking to hide features on a map using another color.  This was simple to do in desktop.
HoustonCo
Created an "Idea" for this to have included on future builds.
https://community.esri.com/ideas/14579
