Exported Joined SDE Table Empty
1187
09-09-2024 09:50 AM
MeKohler
Hi, I have a polygon layer in a SDE which I joined to a table in a different SDE.  The join is successful but when I export the joined layer, the exported layer is empty.  I then exported the polygon layer into a file geodatabase, joined it to the table and was able to successfully export the data.  The export works when the data is in a file geodatabase but no when its in a SDE.
One thing that I should add is that the primary key in the polygon layer is a text field, while the primary key in the SDE table is Object Id.
Michael Kohler
DanPatterson
MVP Esteemed Contributor
The fields should be of the same type and have matching contents for a join to persist
... sort of retired...
MeKohler
But why does the join work when the polygon layer is in a file geodatabase?
Bud
Legendary Contributor
What version of Pro and what kind of database? For example, Oracle 18c 10.7.1 enterprise geodatabase.
If you cast one of the join fields in a query layer or database view, so that the datatypes are the same, do you still see this issue?
SQL:
SELECT
CAST(MY_TEXT_FIELD AS INT) AS MY_TEXT_FIELD,
T.*
FROM
MY_TABLE T
