Export Table tool not showing Output Location
3843
6
02-22-2023 08:00 AM
Craig_Eissler_Iceman
I am attempting to export a CSV Text Stanadlone Table into my Geodatabase; thereby converting it to a File Geodatabase Table.
However, as you can see from below, I do not see the 'Output Location' option where I would specify my GDB..?
Tags (1)
OK, so they've gotten rid of the Output Location input box in 3.0 (see below from 2.9) -- and just built it an the Output Name into one Output Table box. ...
BarryNorthey
The Output Table is set to the Project's Home FGDB by default and only the Table name is displayed if this option is set: BarryNorthey_0-1677084276850.png
Hover the pointer over the Output Table name to see the full path in a pop up.
Click the browse button to the right to export to a new location.
Thanks, but where exactly is that Geoprocessing Setting?
If I click on that tool's Environments, this is what I see:
OK so I found that Geoprocessing Option, but no sure what that has to do with the 'Output Location' input option that is no longer in the tool, as far as I can tell..? Or, is there some other Setting that controls that.
...I may not want to export my Table to the "default" GDB.
BarryNorthey
Click the browse button: BarryNorthey_0-1677087249847.png to set a path to another FGDB. You will have to supply a table name.
If you browse to a folder location (not an FGDB) it will create a dbf table.
mthompson
Many tools used to have the Output Location as a separate input, like you mentioned, which was very handy to be able to change it for all tools at once. Now that it is part of the Output Table field, I don't see a way to change the location for all my tools without having to go to each one of them individually. Is there a different way to do this now?
