Export Raster bug?
4154
7
07-11-2019 09:32 AM
by Anonymous User
Not applicable
I think there is a bug with Pro 2.4 with the Export Raster tool. I've attached two videos to illustrate what is happening but I'll explain. When you use the export raster tool (right-click raster -> Data -> Export Raster) and check the box for "Force RGB" under Renderer Settings instead of the output being in RGB it is stretched.
However, when you check the box "Use Renderer" under Renderer Settings the output is in RGB. They are doing the opposite of what they should. Like I said, unless I'm completely misunderstanding this, this is a bug. I have reported it but the bug reporting site just doesn't seem like I can go to as in depth as this so maybe someone can pass this along with an elevated priority. I also don't know if they are looking into it because I haven't received any kind of follow-up. If I'm misunderstanding can someone please explain.
First video is me using the "Force RGB" setting and the second video is me using the "Use Renderer" setting. Just play them through. the Use Renderer video is a little longer because it seemed to take more time processing. Thank you!
KoryKramer
Esri Community Moderator
Hi Bryan,
Sorry for the delay.  I checked in on this and the raster team has the issue entered in their backlog.  So we've got it.  Thank you for reporting.
Cheers
KoryKramer
Hi Bryan,
Thank you for posting this.  When you say that you have already reported it, what that through here? https://support.esri.com/en/contact-tech-support
Just trying to understand where that initial report was made.  In the meantime, we'll make sure that somebody on the raster team takes a look.
Cheers
by Anonymous User
Not applicable
Yes, I reported it through the Tech Support page. I submitted two reports; one for Force RGB, and one for Use Renderer. I think I submitted it earlier this week or maybe last week, sorry, can't remember exact date. Like I said, I never hear anything back from submitting bugs and I checked the support search for bugs and didn't see it so I didn't know if it went anywhere. I thought this seemed like an important flaw to point out which is why I also posted it with a video.
by Anonymous User
Not applicable
Have you heard if this will be addressed? How do I know if technical support has received my bug report?
KoryKramer
Hi Bryan,
Cheers
by Anonymous User
Not applicable
Thanks Kory!
KoryKramer
Looks like this will be fixed in ArcGIS Pro 2.5 scheduled for January.  Hopefully you don't get too used to doing it the opposite way
by Anonymous User
Not applicable
That's great to hear, thank you for the update!
