Export Package Layer not including data
8736
10
02-22-2023 08:43 AM
dingwall
Hello! I am trying to export a layer package, however the .lpkx file does not seem to be including the underlying data, and results in a broken data connection with another member of my team attempts to add to their map.
I am using ArcGIS Pro 3.0.4 in Parallels Windows Desktop, so am was not sure if this was a result of running on the virtual machine (all other ArcGIS Pro capabilities have worked thus far).
When my colleague exports a layer package, I am able to insert the layer successfully with correct data connections. It looks like his file exports to a "Packages" folder when looking at the layer source info, versus my exports referencing the folder where the data is on my local machine.
Both export options "upload package to Online account" and "save package to file" have the same issue.
Thanks for any tips!
Robert_LeClair
Esri Esteemed Contributor
You mention that you're using Parallels Windows Desktop on a Mac within a VM.  Is your colleague also using a VM or a local install of ArcGIS Pro on a Windows PC?
LayerItOn
Does this cause problems? I have a colleague who packaged up some layers to share with me, and no matter what most of the layers are broken and won't repair. He is running windows on a parallel on Mac.
Scott_Harding
I'm having the same issue (Pro 3.1, also using Parallels but data recipient is not). I can see clearly that the data isn't being included in the package and it tries to link to my local drive for the data. Any luck finding a fix?
Robert_LeClair
@Scott_Harding and @LayerItOn - this morning I was reviewing the internals and learned of BUG-000151772 - The layer package (.lpkx) file is missing the layer's data source when opened in ArcGIS Pro.  It's reproducible in ArcGIS Pro 2.9.0, 3.0.1 and in VM's using ArcGIS Pro 3.0.1.  It's currently under review by the Support Services team with currently no workaround.
LayerItOn
Thanks for letting us know!
Scott_Harding
@Robert_LeClair It's been a while. Do you have any update on a fix for this bug? Thanks!
Robert_LeClair
Hi Scott - I'm seeing BUG-000151772 as Under Review currently as of 5/28/24.
AlfredBaldenweck
MVP Frequent Contributor
Two people (myself included) in our office have encountered this issue in 2.9.5.
Opening the lpkx just shows LYRX files, referencing the original datasource.
DebSF
I'm having this issue too, even in Pro 3.4 (according to BUG-000151772 it was fixed in 3.3).  I select "Save package to file" and "Include Enterprise and UNC Path Data" but if I try and open the saved layer package when I'm not signed in to AGOL, it prompts me to sign in.  Has anyone worked out why this is happening?
