Export Layout - CHg Settings so that the default File Name is NOT the layout name
2075
01-13-2023 03:40 PM
Marie_Ducharme
In ArcGIS Pro, when the user exports a layout, the file name of the export file is default the name given to the layout. This is good at times, but sometimes, I would like the default name of the file to be different than the layout name....
I try to keep the Layout names concise, so I can see many open names at once....and then the files I export may need a more explicit name...but every time I re-export, the default name goes back to the layout name...
Example: I have a layout called ANSII E in my project, but I want the pdf file to be named "Fig 2 Property Overview for Project Proposal.pdf".
I can change it manually, but every time I export to pdf, the default name 9the layout name) gets inserted back in. Its tedious. Not sure I am explaining myself clearly...ask away if not! Cheers.
