Error while installing ArcGIS Pro for the first time in a local machine
11056
9
09-03-2022 09:29 AM
nik_geo
Hi, I am trying to to install ArcGIS Pro 3.0 on my personal laptop following the instructions (https://helpcentre.lancaster.ac.uk/servicedesk/customer/kb/view/6919925?applicationId=0185474f-cbad-...). After downloading the software I am receiving an error (also, please see the attached images):
The file 'C:\Users\Geography\Documents\ArcGIS Pro 3.0\ArcGISPro\ArcGISPro.msi' is not a valid installation package for the product ArcGIS Pro. Try find the installation package 'ArcGISPro.msi' in a folder from which you can install ArcGIS Pro.
I browsed to the file called ArcGISPro.msi (picture with the number 1) and then I got the error (picture number 2). I also tried installing the software by connecting to the Uni's VPN using the Global Protect, without success. I am using Windows 10.
Note: I am using my Uni's credentials to download and install the software on my local laptop.
nik_geo
I managed to solve the problem. So, as you can see in the image attached, somewhere in my laptop there was an ArcGIS Pro (version unknown) and I couldn't locate it (file size >3gb). I couldn't uninstall the software using Windows Apps and Features, or Ccleaner or Windows Troubleshooter. I found a software called IObit Uninstaller and it removed the software. In this way I finally installed the newest version of ArcGIS Pro (3.0). It turned out the older version was causing the issue.
DanPatterson
MVP Esteemed Contributor
try saving the msi to a folder without a space in its path
... sort of retired...
nik_geo
I deleted the spaces, nothing.... I deleted the dots  from 'ArcGIS Pro 3.0', still the same error. Also, I tried this solution without success.
DanPatterson
Your instruction link in local to your university, so isn't good for troubleshooting by us.
What I do.
I download the *.exe from my My Esri to my local machine  (simple folder so it is easy to find and keep).
I run the *.exe and it yields a *.cab and the *.msi file.
Finally, I double-click on the *.msi which starts the install process.
nik_geo
That's exactly what I did. I run the .exe then the .msi. During installation using the .msi I'm getting the issue. I apologize for the link, I didn't know you couldn't open it.
JoshuaBixby
Your first screenshot shows "Pro 2.5" in the path in the dialog, and the second screenshot shows "Pro 3.0" in the path in the message box.  Do you have any Pro versions already installed, say Pro 2.5?  If so, the installer may be looking for the Pro 2.5 installation media to remove your current install before it will proceed with installing the newer version.
nik_geo
Yes I have it but change the path to the .msi at this stage but the problem persists. Should I delete the older version?
DanPatterson
contact your University's esri contact person, something is missing  in the process
nik_geo
Already did but it's the weekend so no one's working. When I fix it I'll post the answer here.
nik_geo
